The Ford Barn
-   -   hot water heat (https://www.fordbarn.com/forum/showthread.php?t=187420)
Gino 01-20-2016 07:28 PM
hot water heat
hi, so i installed a heater core that i purchased separately from the kit i purchased from Snyders. i don't get a lot of heat for my troubles, keep in mind i live in the north east. considering blocking the radiator from the wind as I've seen done in the past. anybody have any expertise here, i sure would appreciate the advice, thanks
Mitch//pa 01-20-2016 07:57 PM
Re: hot water heat
Are you running a thermostat and getting flow through the core..
H. L. Chauvin 01-20-2016 08:04 PM
Re: hot water heat
Hi Gino,
Also, maybe in addition,just a few more details?
Heater core bought, (maybe a "used" core?) ........... and bought separate from Snyder's maybe a (new?) Snyder's kit?
Could maybe a "used" heater core be assumed to possibly be a "used clogged" heater core, a heavily outside painted core, or an undersized core?
Is heater core clean .... inside and out?
If radiator blocked, do you have an engine temperature gauge? Engines can become overheated ...... even in cold weather.
JtownJoe 01-20-2016 08:17 PM
Re: hot water heat
Hi Gino, I live in Western PA AND I have to keep my radiator blocked about 1/2 way up to keep the water temperature close to 180* even with a 180*thermostat. As soon as temp. drops below about 20* it needs help to stay hot enough. Also noticed mine won't circulate well at an idle it needs the rpm's up to keep inside warm enough. I out some temp. clear heater hoses on so I could see what was going on & then switched back to the regular hoses.
JtownJoe 01-20-2016 08:24 PM
Re: hot water heat
PS: Forgot to mention I found some "black plastic" about 1/16" thick and it slips between the radiator fins and the s/s cover in front of the radiator and hardly shows. It should be easy to find and is easy to cut to fit your needs. FWIW
C26Pinelake 01-20-2016 09:50 PM
Re: hot water heat
I bought the full kit from Snyders and I have great heat. I live in Canada and I had the A out yesterday and it was minus 5 degrees and I was comfortable , not hot but comfortable. I also added the thermostat to their kit. Wayne
noboD 01-20-2016 10:47 PM
Re: hot water heat
AN infrared gun will tell you where the heat is or not. Depending where you hook it up you may not be getting any flow through the core.
fords 01-21-2016 02:25 AM
Re: hot water heat
Referencing FLOW -I was told the importance of the waterpump shaft/impeller portion of the pump must be dead on in the housing to provide good proper water flow. Is this something anyone has heard of. Thanks Guys
Tom Wesenberg 01-21-2016 04:21 AM
Re: hot water heat
Need details of the installation.
As Mitch said, you need a thermostat, and also the heater inlet hose MUST be coming from the engine side of the thermostat, and the heater return hose must go into the block inlet side, either the pipe hose, or casting on the left side of the block.
Gino 01-21-2016 08:57 AM
Re: hot water heat
Hi, the heater core is new out of the box. I will buy the gauge and a thermostat. Also I will block the radiator and rely on the gauge to make sure she doesn't get to hot. There's a joke there I think. I hadn't thought of black plastic for blocking. I planned on fabricating some sheet metal and paint it, then I can brag about my handi work. Thanks very much for the help, good to know I havnt screwed up too much.
Mitch//pa 01-21-2016 09:06 AM
Re: hot water heat
So your not running a stat??? You need it>>>>> A properly operating stat should regulate the cooling system at its specified degrees without covering the radiator....
CarlG 01-21-2016 10:52 AM
Re: hot water heat
1 Attachment(s)
You might try one of these:
Cool Hand Lurker 01-21-2016 11:33 AM
Re: hot water heat
Carl, what is it? A grille, louvered airflow regulator, heater core? Where does it go?
Help me out of the dark. :cool:
CarlG 01-21-2016 11:50 AM
Re: hot water heat
That is a 1930-31 Globe Winterfront. It mounts in front of the radiator and has movable louvers that are controllable in the cabin.
Cool Hand Lurker 01-21-2016 11:52 AM
Re: hot water heat
Thanks Carl. I don't suppose you can get them at the corner store anymore, eh?
CarlG 01-21-2016 12:04 PM
Re: hot water heat
NAPA is currently out of stock :D
Actually, the one I have is NOS, but it is missing the cabin control piece. If I use it I will have to gerry-rig something.
Tom Wesenberg 01-21-2016 01:09 PM
Re: hot water heat
The winterfront is the old way to control the engine heat, but to get coolant flow through the heater core you need to create higher pressure for the heater inlet hose than for the heater outlet hose, and to do this you need to either block off the radiator flow with a washer (poor idea), or better yet use a thermostat to control engine heat and create a high pressure zone for heater coolant flow.
CarlG 01-21-2016 01:23 PM
Re: hot water heat
2 Attachment(s)
Here's the perfect way to do that: (Vintage Precision Products)
Mitch//pa 01-21-2016 01:57 PM
Re: hot water heat
Yep what Tom said,,,,
Charlie Stephens 01-21-2016 02:12 PM
Re: hot water heat
How and where are is your hot water pick up and return? How about photos?
Charlie Stephens
