The Ford Barn
-   -   Help...oil pan won't fit or clear the pickup (https://www.fordbarn.com/forum/showthread.php?t=187028)
Mark's 37 01-15-2016 07:24 PM
2 Attachment(s)
Tried to install the oil pan today on the 37 221. It has the shorter late pump and pickup that came with the unassembled engine. The pickup interferes with the baffle. The baffle edge sits down on the the pickup screen and won't go past it. Is this a mismatch or am I missing something?
flatheadmurre 01-15-2016 07:32 PM
Re: Help...oil pan won't fit or clear the pickup
A minor anglegrinder adjustment later it fits just fine !
The baffle and the newer style pump/pickup was never ment to fit togetter.
Walt Dupont--Me. 01-15-2016 07:37 PM
I take a torch and snip both sides of that baffle and remove it. Walt
Mark's 37 01-15-2016 07:38 PM
So the baffle needs to be "massaged"?
Mark's 37 01-15-2016 07:44 PM
Getting my cutter and snips out. Thanks.
Mark's 37 01-15-2016 08:03 PM
Almost there. Does the cup in the bottom of the pan need to go too?
Walt Dupont--Me. 01-15-2016 08:15 PM
Yea, that little cup has to be removed, It's easier than it looks, prick punch the middle of the 4 spot wells, take a 1/4in. drill and just drill the top off the weld, the cup will dap right off, then I grind the weld flush, if you think it's a little thin at them 4 spots just put a little brass on those spots. Walt
Mark's 37 01-15-2016 08:28 PM
Got it. Thanks Walt, saved my day once again.
