The Ford Barn
-   -   Points (https://www.fordbarn.com/forum/showthread.php?t=186865)
Brianfrench65 01-13-2016 02:59 PM
Points
With original points, as the plastic rubbing block wears, and the point gap closes, does that also slightly advance the timing?
Thank you.
Brentwood Bob 01-13-2016 03:34 PM
Re: Points
yep.
BRENT in 10-uh-C 01-13-2016 03:59 PM
Re: Points
Actually it retards the spark. As the point block wears, it allows the contacts to open later because the distributer cam as rotated further before the ramp engages the point block. If the distributer cam has rotated more, so has the piston meaning it is later in the firing cycle --or less BTDC degrees. (more degrees BTDC would be the same as more advance)
sphanna 01-13-2016 04:39 PM
Re: Points
Brent is correct
Rex_A_Lott 01-13-2016 05:01 PM
Re: Points
After you go through this a few times, you will learn to recognize retarded time just by the sound. If its real bad, the car will cut off if its idling and you push the spark up.
On the other hand, if you only have one car, and you dont drive it much, it may be long enough between times that it slips up on you and you dont recognize it.
Good Luck!
Brianfrench65 01-13-2016 05:13 PM
Re: Points
Awesome explanation. Thank you very much.
pgerhardt 01-13-2016 07:15 PM
Re: Points
The teacher in me bubbles up as I try to clarify the issue. The spark is generated when the points open (not close) and collapse the magnetic field in the coil. So a worn rubbing block will allow the points to stay closed longer retarding the the spark. In other words: What Brent said! :D
Brianfrench65 01-14-2016 09:58 AM
Re: Points
Fantastic, I can picture the scenario very well now.
I noticed that my initial point setting closed up rather quickly (200 miles). Then 500 more and I was still set at .020. I figured the point block wore into the cam ( new Stipe cam). Just was curious about what that did to the timing. I also understand now, it also effects the condenser and coil saturation timing.
Thank you so much for your input and willingness to share knowledge. I appreciate this site and the participants.
Thank You; Brian
Brentwood Bob 01-14-2016 03:17 PM
Re: Points
appreciate the correction by others, This old dog learned something too.
Bob
Brianfrench65 01-25-2016 01:17 PM
Re: Points
I just received my November/ December 2015 " TheRestorer", and on pages 8,9&10 is a full description of timing and relationship to timing. This is the full lesson, on the subject.
Thank you all for contributing to my education.
C26Pinelake 01-25-2016 02:26 PM
Re: Points
About time you received it as it is close to being February!! Wayne
700rpm 01-25-2016 07:26 PM
Re: Points
You just got your Nov-Dec issue? That's two months late!
Brianfrench65 01-25-2016 07:51 PM
Re: Points
Ray:
I live in a very rural community, so I guess my mail is very slow.
It seems that all of my publications are held up somewhere.
Thank You.
