Radiator Question True or false
When you flush the entire cooling system and replace it with new antifreeze if you only put in antifreeze( without deluding it with water) you have decreased )the efficiency of cooling , freezing ,and lubercation ability ?? Gene in MN |
Re: Radiator Question True if you use full strength ,,,False if you use 50/50 premixed
Re: Radiator Question Unmixed antifreeze can freeze.
Re: Radiator Question 50/50 is what you want.
Re: Radiator Question 1 Attachment(s)
Try this, courtesy of Detroit Diesel:
Re: Radiator Question Quote:
Opinions, opinions though :rolleyes: |
