Removing a decal from metal I have a pretty nice Ford Dealership I.D. decal on the inside dash and I intend to paint the dash and would like to save the decal. Does anyone know of any liquid I could use to help remove the decal without ruining it? It is about forty to forty five years old and is from Hollywood Ca. Thanks for your suggestions.
Re: Removing a decal from metal Randy that's a tough one. Before I did anything I'd take some quality photos with a scale next to it so you could at least have it reproduced. Beyond that, I got nuthin'. Wayno
Re: Removing a decal from metal I work for a living doing graphics and signs and I do not think there is anything that can lift it while not destroying it. I agree though, take as many detailed pics as you can so that it could be reproduced.
Re: Removing a decal from metal Being that old it's probably a water based slide off decal.
As stated after taking some pics, try using a water soaked rag/sponge held in place for a period of time to see it the water based glue softens up enough to remove it. |
Re: Removing a decal from metal Check out some old book, manuscript and antique restoration sites..
Search for the particular problem you have... I used to do a lot of clock restorations.. There are so many tricks to recover designs and details of clock cases...And I know that old book, manuscripts, old photos can be restored by techniques most people have never heard of..So do a lot of home works and ask a lot of question before you do something that may destroy what you are trying to save. They may actually have something that will lift the entire decal or that may transfer it to a clear acetate sheet or something....Good hunting. This is for a different problem but at least you get the idea..someone has developed a solution for restoring decals....I am sure real antique restorers have countless other techniques. https://www.youtube.com/watch?v=WOwU0Jph5AQ |
Re: Removing a decal from metal 3 Attachment(s)
http://[email protected]So far, this is my best picture. As you can see, I am very bad with a camera. I will try more pictures. At least, you can see what I am dealing with - the "Red" dash.http://[email protected]
Re: Removing a decal from metal might try steam.
Re: Removing a decal from metal Yeah. Maybe you should get a "grown up" to take the picture. I'm funnin' you Randy. Keep trying. Wayno
Re: Removing a decal from metal As bad as the pictures are it looks like the dash may have been clear coated including the decal. If that is the case then kiss the decal goodbye.
Re: Removing a decal from metal Digital camera ? I assume so. You may have a "Macro" mode for shooting close pictures. If you haven't tried this, give it a "shot"
Re: Removing a decal from metal Hey, teasing me about my "camera talent" doesn't bother me. I'll just take my "brownie" next time and use it. Thanks again and I intend to get a very good picture before I try any liquids. I may just come up with something to just cover the decal and paint over it and then uncover the decal. Not the best way, but at least I will still have the decal. Thanks again. Randy
Re: Removing a decal from metal The 'something' you use doesn't need to be solid thing. I've used vasoline as a paint block when working on certain pieces. By carefully covering the target area with a generous coating, paint can be applied around it. After the paint has COMPLETELY dried, remove the vasoline to expose the original surface. Tape can be used to create sharp edges - the tape is removed prior to painting. Good luck.
Re: Removing a decal from metal Watch out if you put any tape over the decal to protect it while painting. The decal may become damaged when you remove the tape. If you reproduced the decal, it will look nothing like the old patina'd decal you now have. I do like the idea of painting around it. That will be tough as the prep is going to be tedious as well.
Re: Removing a decal from metal 1 Attachment(s)
Is your dash original paint? If original don't remove the paint just try to restore it..In restoration of old clock faces we never redone an old face unless it was totally gone or offensive to look at.. |
Re: Removing a decal from metal Everyone is entitled to do what they want with their own car, if it was mine I would not want the mix of new and old. I would either leave the dash and decal alone, or have someone reproduce a new decal without the patina.
Re: Removing a decal from metal Oh for the photo. Use best quality setting and take it from farther away. You can then crop or blow up an in focus shot. The decal guys would photoshop the picture to your liking then make a new decal. Make extras.
Re: Removing a decal from metal My '50 Fordor had a decal about oil requirements and tire pressure and when I painted the dash and glove box I taped over it. Im happy with it but my car is by no means a restoration...Mark
Re: Removing a decal from metal If you happen to find a way please post it here. I have a broken windshield from a Model A that has some old travel stickers on them. Would love to save the stickers and preserve them, but also need to replace the glass. Rod
Re: Removing a decal from metal Quote:
Re: Removing a decal from metal Where is The "Late" Jim Osburn when you need him. He was the master of removing and re-making of stickers and decals. RIP Jim.
