The Ford Barn
-   -   Outside Mirrors For 190A (https://www.fordbarn.com/forum/showthread.php?t=184130)
Bob Bidonde 12-05-2015 12:04 PM
For those of you needing mirrors for your 190A Victoria Coupe, I find that Vintique's A-17741-BR mirrors perfectly fit the upper door hinges on my Steel-Back. That is, the width of the channel shape on the mirror's arm is a neat fit onto the height of the 190A's upper door hinges.
However, the mirror's mounting bolt is 0.237" diameter and the 190A's door hinge pin is 0.281" diameter. This will necessitate opening the mounting holes in the mirror to accommodate the 0.281" diameter & installing longer pins. I use roll pins. There are 2 set screws in mirror mount, so hinge bolt & nut is not necessary.
I will post some pictures later on.
Mike V. Florida 12-06-2015 12:34 AM
Re: Outside Mirrors For 190A
Thank you!
