rear window lace 1930 pickup. I have disassembled my pick up cab and sand blasted the rear of the cab. the inner flange for the window is now rather lacy. sand blasting will tell you things you really don't want to know. I know the inner frame is available, but what is the best way to repair the rear cab section. i'm sure some of you guys have encountered the same problem. i have taken care of the bottom and corners with patch panels.
