Window Regulator Main Spring Does any one know the trick to installing a new main spring in a Model A window regulator? I swapped a main spring from a broken regulator to a good regulator that was missing the spring. However, I cannot get the preload correct...it's a strong spring and the can't wind it around far enough. There must be a tool or trick to accomplish this.
Thanks. |
Re: Window Regulator Main Spring Can you grip the end of the spring with a Vice Grip, then use a screwdriver through the Vice Grip for leverage to wind and hook the spring?
Re: Window Regulator Main Spring Quote:
Re: Window Regulator Main Spring Also make sure the regulator is in the "open" position as the spring has the least tension on it.
Re: Window Regulator Main Spring I just installed a spring on my drivers side door yesterday. I finally had to remove the regulator and disconnect it from the window channel. Then raise the arm to it's highest point to get the spring on (spring will have least tension at this point).
Re: Window Regulator Main Spring Mike V you are backwards when you roll the window down the spring goes into tension to aid you in lifting the weight of the glass. it is best to remove the regulator and put in the up position and the springs go on pretty easy.
Re: Window Regulator Main Spring This is what I do: I use a length of steel wire (the type used for electric fencing) and make a short loop to pull on the outer loop in the regulator spring. I connect the other end of the wire to a wrench to create a T- handle. Then with the regulator clamped into a vise - I can pull the spring into position - and sometimes I need to push the spring down to get into its final location.
Re: Window Regulator Main Spring I hope this isn't a stupid question....but does the spring help hold the window up? Both my windows slowly work their way down as you drive along...
Re: Window Regulator Main Spring There's also a small spring that acts as a crank lock, and it's under the metal cap.
The window is easy to crank down as you have gravity helping you. The spring unwinds as the window is cranked up and then is re-tensioned as the window is cranked down. I have replaced several without a problem with the regulator in the full up position. My opinion. Chris W. |
Re: Window Regulator Main Spring Thanks guy's....I have more hope now...lol
