I'm not rich but my Model A is !! I have my the carb adjustment valve all the way off and according to my plugs, and my exhaust I seem to still be rich. What is wrong !!
Re: I'm not rich but my Model A is !! Prior to trying to investigate oversized jet problems, did you check to see if:
1. Your carburetor float level may be set too high? 2. Your GAV may be not seating properly and leaking? |
Re: I'm not rich but my Model A is !! If it hasn't already been done you may need to replace your jets with a set of flow tested jets from Renner's.
Re: I'm not rich but my Model A is !! If you are using an air filter you should also use a balance tube on the carb.
Re: I'm not rich but my Model A is !! sounds like carb rebuild time or just purchase one from berts whichever suits you best
are you setting the air bleed properly? |
Re: I'm not rich but my Model A is !! How do you set the air bleed ?
Re: I'm not rich but my Model A is !! |
Re: I'm not rich but my Model A is !! 1 Attachment(s)
If you have an air cleaner on it try taking it off and see what happens.
I've had problems when the filter gets to dirty. |
