The Ford Barn
-   -   2 tooth steering box l/h drive (https://www.fordbarn.com/forum/showthread.php?t=18104)
cmahlonpease 10-19-2010 10:11 AM
adjusted box per Les Andrews manual binds up left and rt. 1/2 turnoff center and makes a groaning noise from column steering is smooth and bind free when wheels off pavement binding seems to be in column as no free play in wheel.
MikeK 10-19-2010 10:17 AM
Re: 2 tooth steering box l/h drive
If the most-used center section of the worm & sector are worn, adjusting the play out of the center will leave you with a bind to the far right and left. That is why the gears are replaced during a rebuild.
Mike V. Florida 10-19-2010 11:32 PM
Sounds like your gears are real worn in the center.
