The Ford Barn
-   -   pinion and ratio 3,78 help (https://www.fordbarn.com/forum/showthread.php?t=180997)
roert 10-24-2015 08:34 AM
Hello
Today I wanted to change my new pinion 3.78.
the old is a 4.11 Pinion.
now the stock not fit.
the inside diameter of the bearing is too large.
Does anyone know exactly what I need to order for storage (which I have everything completely)
nice would be the item numbers of Macs
thank you
roert 10-24-2015 08:35 AM
Re: pinion and ratio 3,78 help
the camp is installed the Timken 48-4621
roert 10-24-2015 08:36 AM
on the new pinion 3,78 stand 9602
roert 10-24-2015 08:43 AM
and how can I
Drive Pinion Bearing Double Race - Ford
Remove from the housing
flatheadmurre 10-24-2015 08:54 AM
Some pics so we can identify what parts you got to start with and what new ones you got.
If its only the wrong bearings you got or is the ring and pinion different ?
A parts and a shopmanual aint a to bad thing ;)
JM 35 Sedan 10-24-2015 09:00 AM
I can't answer your specific questions, but here is a technical post that was on the HAMB that may be of some help to you...
http://www.jalopyjournal.com/forum/t...o-axle.812569/
roert 10-24-2015 09:22 AM
1 Attachment(s)
here the picture
JSeery 10-24-2015 09:24 AM
Might also help to provide the year of rear end you are working on.
roert 10-24-2015 09:28 AM
sorry here the right pic pinion and ratio 3,78 help
1 Attachment(s)
sorry 1 6/16 is correct!!!!!
roert 10-24-2015 09:29 AM
ford coupe 1936
roert 10-24-2015 09:47 AM
1 Attachment(s)
i ned this one
flatheadmurre 10-24-2015 01:01 PM
The first one you have looks like something out of a quickchange rear has the shaft cut down for a supportbearing ??
deuce lover 10-24-2015 01:39 PM
Looks like the pinion has been machined down to take the 33-34 bearing set .Also as flatheadmurre mentioned the end for the driveshaft has been machined for possibly a quickchange setup.You will have to find another R & P set as you should not mix pinions with ring gears.
JM 35 Sedan 10-24-2015 04:34 PM
Also, that pinion gear in your second picture has six splines. Most likely, your '36 driveshaft, if stock, would have 10 splines on its pinion end, and you would need a 10 spline pinion.
