Why use 12 volt starter? When I switched my car to 12 volts in 2009, I retained the 6 volt starter. As the car gets LOTS of use, I have had some challenges over the years that I contribute to 12 volts on 6 volt starter. In my opinion the 6 volt starter will "slam" harder into the flywheel ring gear and spin faster when receiving 12 volts. Over the year I have had:
1) Broken (2) original style bendix springs. Replaced with a "barrel" style bendix that has held up well till now. 2) Bevel of the barrel bendix gear teeth did not mate well with flywheel ring gear. The extra thrust of the 12 volts effectively "pushed" the ring gear out of position on the flywheel and buggered up the ring gear teeth. Grinding a better matching bevel on the bendix teeth and installing a tight fitting ring gear has solved this problem. 3) After several years of use, the keyed hardened steel bushing of the bendix that slides over the starter shaft cracked at the woodruff key slot, letting the woodruff key and barrel set screw wiggle and eventually shear and wear off. As my car will continue to get LOTS of use, I have decided to use a 12 volt starter from now on to reduce the stress on the starter bendix/ring gear, hopefully eliminating my previous problems over the years. While "your mileage may vary", I hope my experiences may help someone else avoid similar challenges. Please, no need to comment whether changing to 12 volts is "right or wrong". Peace, Phred |
Re: Why use 12 volt starter? I had one explode in the bell housing . but I still use the 6v in a 12v system . I should change also .........
Re: Why use 12 volt starter? I have a different experience---
restored starter in 1968 with cleaning ,paint, and grease on bushings when apart to fix crummy babbitt in 1985 replaced ring gear and bolts/locks on bendix because of 2 locked starter jammed bendix episodes since 1985 only work---4 batterys through the years i have been asked if I have 12V because of my bright lights and fast cranking----I attribute this to proper restoration using new lockwashers and a higher than normal charge rate---new lockwashers bite through paint and conduct electric better than old corroded worn ones, the higher charge rate keeps the battery "up" |
Re: Why use 12 volt starter?-Grounding star washers These "double star washers" work very well.
I first saw them used on IBM machines for all grounding situations 48 years ago. http://www.grainger.com/product/GRAI...AS01?$smthumb$ They have two areas (both on the OD and ID of the washer) that dig into the metal for a good connection. That is why they are called "Internal/External Tooth" washers. Another style: http://www.grainger.com/product/GRAI...APPD&pbi=2DB86 |
Re: Why use 12 volt starter? Thanks for posting that information....I have two As, both with 12v to 6v starter...they will get changed to 12v this winter to avoid the problems you had......great information.......that's what makes this site so great
Re: Why use 12 volt starter? Quote:
Re: Why use 12 volt starter? Has anyone used one of the gear reduction 12V starters? I had a "new in the box" one given to me that I am considering using. Besides the fact that they don't look original?
I use them on the flathead V8's I build also. |
Another even easier solution is to take yourself off to a wrecking yard and get hold of the battery cables from one of those little Asian rice burners. These cables are small diameter and cause a voltage drop along their length. I have used such a cable on both the active and earth side of the battery to get the desired result. They have PLENTY of capacity to do everything else in the car. |
You can do the same thing with an original generator (not the Power House style) to make it a 12 volt generator. Very easy for an automotive electric shop to put in 12 volt field coils for you. That, with a hidden electronic voltage regulator added, and you have a sweet system that looks more original than an alternator. :cool: |
Re: Why use 12 volt starter? A trick I have been using for years that I got from my father is to take a bendix spring
and put it on the starter post and hook the battery cable up to it. This cuts the voltage down to about 8 volts the car starts a little faster with out killing everything. You have to grind down one of the eyes thinner to fit on the post. It really works...... |
Follow Up Received the new barrel style bendix and 12 volt starter.
Confirmed bendix had proper bevel on gear and installed all. After a few weeks of use, I am happy. Starter engages much gentler and turns engine over plenty fast for starting. Peace to all. |
