Generator Stud and Nut Question 3 Attachment(s)
Hi,
I am mounting my generator to the front of my manifold using the 9/16" stud and special long nut arrangement. When I took it apart there was no lock washer in my bag. Is one supposed to be used or desired? Also plan to use anti-seize on the threads since I had a tough time getting it off the stud. A few pics below off ebay, and green book. Looks to me that no LW is used on the 42 up generator mounting. |
Re: Generator Stud and Nut Question All the 8BAs i have seen have had lock washers. Don't know about other versions. Cheap insurance.,...jack
Re: Generator Stud and Nut Question Just as a side note on spring washers. Caterpiller do not use them.
It has been proven that they can cause failures before a properly torqued nut (without a spring washer)fails. |
Re: Generator Stud and Nut Question Quote:
Re: Generator Stud and Nut Question Thanks everyone, I'll be using a regular lock washer.
Re: Generator Stud and Nut Question Yes lots of great knowledge and helpful people here.
Re: Generator Stud and Nut Question This summer I had one come loose. I had no lock washer on it, like stock. I fixed what got broke, and drilled the nut for some safety wire, tying it back to the generator mount.
I would say DO NOT use anti-seize on the threads. |
Re: Generator Stud and Nut Question 1 Attachment(s)
I have also been told that spring washers can eventually fail under load. I use a 1/4 in. round steel spacer on top of the square washer so as to make it easier to align and "really tighten" the big nut. 20 years and no problems yet (knock on wood).
Re: Generator Stud and Nut Question Good idea 19Fordy.
Re: Generator Stud and Nut Question Where can a guy find the 9/16" stud?
Re: Generator Stud and Nut Question so cal hot rods sells them
Re: Generator Stud and Nut Question Sorry- So Cal Speed Shop
