Model T door dimensions Found a solid door for a T not a open door but for a closed truck or car. Could someone post the dimensions, heighth and width. How can I determine it is a for a Model T? Is there and Ford Inscription or stamping on the doors to determine it is indeed Ford?
Re: Model T door dimensions Robert, I just measured my '27 Tudor door. Now, this door DOES NOT have a bottom, as it has rusted away, but I reckon it would come up at about 46" from bottom to top of the door, give or take a bit. It is 29" wide, measured across the belt line under the window opening. The window is 25" wide and 17 1/4" deep, inside the flanges around the opening. The hinge space is 4" from the top, next hinge is 14 1/2" down from the bottom of the top hinge to the top of the second hinge and 15" down from the bottom of the second hinge to the top of the bottom hinge. Door is 3" thick across the window ledge and 1 3/4" thick across the top of the door.
Hope that helps. Remember also the '28/'29 Closed cab pickup also used these same doors. |
Re: Model T door dimensions hope helps 27 coupe approx 29wide 48vert- recommend you look in parts catalog and see which doors on which models are interchangeable so you can compare responses against different doors made to make sure you have size data for each T door made
Re: Model T door dimensions thanks guys for info
Re: Model T door dimensions 2 Attachment(s)
Robert Lloyd, the T door has a flat piece for the door latch and the 28-9 door has tic tac toe design
