Big Boy Heads 2 Attachment(s)
Help Ford Barn
I am trying to make a decision as to use the big boy heads as shown in the picture on my flathead project. The flathead is 3-5/16 with a ¼ inch stroke, ¾ cam and three carburetors. The 59AB flathead is in a 34 five window coupe frame. Dan |
Re: Big Boy Heads Those are cool heads. I have never seen these before. Who makes/sells them? What is their cost? Do you have a picture of the chamber side that you could post? Do you know any of the specs for these. Sorry lots of questions.https://www.fordbarn.com/forum/images/icons/icon5.gif Bill
Re: Big Boy Heads Decision? What are your other options? Those "Big Boy" heads are very impressive. I too, am not familiar with them. What's the story on them?
Re: Big Boy Heads Bill, I think my brother has a set, not sure though, I have seen them before
Re: Big Boy Heads Quote:
Re: Big Boy Heads no problem, I need to see if he has them, I am pretty sure he does. bought them probably 8-10 years ago.
Re: Big Boy Heads http://www.jalopyjournal.com/forum/t...rare-flathead/ Alaska Jim sent me these links last nite. I don't remember these post's but here are the links for anyone that wishes to read them. Bill
Re: Big Boy Heads The links didn't work . Let me try it again. http://www.jalopyjournal.com/forum/2...g-boys.736482/ & http://www.stromberg-bulletin.com/rare-flathead/
Bob Denton remarked: “Big Boy heads were made in Bakersfield, California”, says Bob, “by a company called CMC Engineering. I do not believe there are more than a dozen sets of these heads around. As you can see, they are quite thick due to the increased cooling capacity and they have a Ford V8 60 type water manifold on them. The company is gone. I bought these in the early nineties along with a new French block, pistons, 4″ crank, and everything I needed to assemble a mean flathead. http://www.stromberg-bulletin.com/wp...-flatheads.jpg |
Re: Big Boy Heads |
Re: Big Boy Heads What amazes me is: Somepeople will go to the time and expense to design a new set of heads for the Flathead , and still use the original combustion chamber. Just flaten out the transfer area and put the spark plug in the original location. Fortunately there are a few people that think. These are beautiful heads, and alittle thought could have made them Great heads.
Re: Big Boy Heads Ron
With all that there is out there regarding technological advancements,I often think about creating a line of heads that use the most modern design and thinking and put them into production. The advancements and knowledge that have been gained since these designs were created is quite a bit. Of courss, with any small production run, cost would be high and production would be low, but I do believe there is market for a truly high performance head. The assumption would be that builder do other mods to obtain the max benefit of the design. But we all know what happens when you assume. |
Re: Big Boy Heads Help
Would you use them on the flathead that I am building for my 34 five window coupe. Thank you Dan |
Re: Big Boy Heads All it takes is a MIG welder and a milling machine and you can have any chamber shape and plug location you want with any brand head.
I have done it several times. It works great. |
Re: Big Boy Heads What are these heads worth?
I see no reason not to, you may have to rasle up something for the top hoses, I don't think the usual center water outlet in a 34 type top hoses will slide right in, due to the hight of the new outlets. Martin. |
Re: Big Boy Heads And then there is all those much longer new bolts needed.... or studs.
Re: Big Boy Heads Flat32 designed and built a set of heads with a modern combustion chamber and pluglocation using modern flow tech. However production costs would have been too high. I wanted a set of them but not sure how many sets he had cast.. Si I did as Pete and JWL did, moved the plug and made myown chambers. Flatattack make a great cylnderhead, I've used them, but they may be out of production..
Re: Big Boy Heads Here is a picture of "Flatrod's" big boy heads in mock-up mode.
