The Ford Barn
-   -   Kingpins (https://www.fordbarn.com/forum/showthread.php?t=178674)
mac101 09-21-2015 05:36 PM
Kingpins
I'm working on my front axle. I've got about a 3/4 inch bow, which I think I can get out. I just noted that there is some play in the kingpins when just inserted in the axle without spindle. How much play can be tolerated in the axle ? Spindle are tight, looks like new bushings.
1930artdeco 09-21-2015 05:40 PM
Re: Kingpins
Sounds like the axle holes are wallowed out. There should be zero play in the axle.
Mike
Al 29Tudor 09-21-2015 06:38 PM
Re: Kingpins
I think the wedge pins tighten up the king pins in the axle.
But only 0.001 after honing bushings for the king pin in the spindle.
Al Leach.
Larry Jenkins 09-21-2015 07:02 PM
Re: Kingpins
Take the 3/4" bow out of the front axle with a hydraulic jacking system COLD! Most Auto Body shops have this kind of machine. Takes only minutes by someone who is knowledgeable.
Larry
Kevin in NJ 09-21-2015 07:27 PM
Re: Kingpins
You may want to look at what I did to straighten an axle.
Axle striaghtening
Do not try to guess by the bow of the axle. At the very least use a long straight edge to sight down the centerlines of the 4 holes. They should be inline.
andyfresno 09-21-2015 07:35 PM
Re: Kingpins
A good axel can usually be had for $50 or less.
katy 09-22-2015 10:36 AM
Re: Kingpins
Kevin, thanks for posting that. I've been wondering about the angles of the holes in the axle.
mac101 09-22-2015 05:21 PM
Re: Kingpins
Just picked up a very nice axle, no bow and King pins fit, $50.
Thanks for the advice.
