The Ford Barn
-   -   No oil pressure (https://www.fordbarn.com/forum/showthread.php?t=178336)
John Walters 09-16-2015 08:03 PM
No oil pressure
Started 30 pickup after a few months and noticed oil pressure gauge at zero, was running okay but I turned it off. Problem?
Boston Bruce 09-16-2015 09:15 PM
Re: No oil pressure
Oil pressure gauge? What oil pressure gauge?
John Walters 09-16-2015 09:26 PM
Re: No oil pressure
after market gauge by previous owner
bikejunk 09-16-2015 09:31 PM
Re: No oil pressure
only really thick cold oil would register on my oil pressure gauge when I first got my car-- fixed the problem by removing it --:)
Chuck Sea/Tac 09-16-2015 09:42 PM
Re: No oil pressure
What did it read before?
John Walters 09-16-2015 09:42 PM
Re: No oil pressure
If I remove the gauge how do you know if there is oil pressure? or am I worrying for no reason, seemed to run normal.
John Walters 09-16-2015 09:43 PM
Re: No oil pressure
to be honest, I never paid much attention to the gauge before I happened to notice this time
J Franklin 09-16-2015 09:47 PM
Re: No oil pressure
Check your dipstick first, then undo the gauge and see if oil gushes out when you crank it over. If not drop the pan
CWPASADENA 09-16-2015 11:20 PM
Re: No oil pressure
In the day, the accessory gauges were usually only 0-10 psi. A stock model A may have 8-10 psi cold and 4-5 psi hot, while running along at 40-45 mph and almost 0 at idle.
A lot of gauges installed later on were 0-30 or 0-60 psi. These gauges may show little or no reading at all.
My opinion.
Chris W.
colin1928 09-17-2015 04:06 AM
Re: No oil pressure
Air in the gauge line from sitting to long bleed it
Mitch//pa 09-17-2015 05:22 AM
Re: No oil pressure
Loosen the lower oil pipe bolt and start it. If oil comes out you have oil pressure
Dave in MN 09-17-2015 07:55 AM
Re: No oil pressure
What Mitch said is what you should do. You may need to pry the oil return pipe away from the block a fraction of an inch to allow some oil out. I usually put a small matchstick between the pipe and the block to maintain a gap. If you have no oil...shut it down quickly. It may take a few seconds after starting for oil to fill the valve chamber and find its way down the tube.
Good Day!
Mitch//pa 09-17-2015 08:02 AM
Re: No oil pressure
Originally Posted by Dave in MN (Post 1158036)
What Mitch said is what you should do. You may need to pry the oil return pipe away from the block a fraction of an inch to allow some oil out. If you have no oil...shut it down quickly. It may take a few seconds after starting for oil to fill the valve chamber and find its way down the tube.
Good Day!
Actually I had it take longer for the oil to work its way down...
Thanks for adding to move the pipe back a little
V4F 09-17-2015 08:42 AM
Re: No oil pressure
if this is a dipper motor , a few #s when cold , but only 1-3# warm . it is a free flow system with only minimum pressure .
