32 Zenith carb. I came into two 32 Zenith carbs. except for the bowl they look like
Zenith 1,2 . how do they compare to the 1&2 for performance ? TIA Jim |
Re: 32 Zenith carb. From what I have read slightly better performance but you need to hog out your intake manifold or run a Model B intake to realize the increase. Get the late Model B manifold with the vacuum intake in the rear as it, in my opinion, looks better. The Model B engine got an extra 10 hp with slightly increased compression, a better cam, and the larger carburetor venturi.
Charlie Stephens |
Re: 32 Zenith carb. Changing to the B carburetor without changing anything else will give you about 2 miles per hour more on the hills and 2 miles per gallon overall. These are my estimates based on my experience.
Re: 32 Zenith carb. Quote:
Just wanted to be sure I understood you, "without changing anything else" means you did not enlarge the A manifold or replace it with a B manifold? Charlie Stephens |
Re: 32 Zenith carb. Jim,
A couple of more things you need to address with the B carb. The choke on the carburetor will not line up with the Model A choke rod. You will need to elongate the holes for the bolts mounting the carb to the manifold or buy special bolts sold by some of the suppliers that have a step to accomplish this function. Your fuel line will also not bolt right up without modification. Charlie Stephens |
Re: 32 Zenith carb. The usual suppliers sell some 5/16 inch bolts that have the threads cut off by the head of the bolt that allow you to turn the carb slightly to line up the choke rod. They also sell a right angle fitting to hook up the gas line. You can also do both yourself. Model B carb is also harder to rebuild.
