Brake pedal sticks Brake pedal was working fine until I tightened the band the other day. Now it does not return to the upright position when I take my foot off it. Any ideas?
Re: Brake pedal sticks Check the spring on the shaft, it may have collapsed or slipped between the ears on the band.
Re: Brake pedal sticks The spring did slip between the ears a little- one side of the first coil is pinched in there! Can I maybe put a flat washer between the ears and the spring to keep that from happening?
Re: Brake pedal sticks Will not be the first time someone has done that fix. :)
Re: Brake pedal sticks Thanks Red!
