The Ford Barn
-   -   Home Made Heater (https://www.fordbarn.com/forum/showthread.php?t=177155)
Bob Bidonde 09-01-2015 08:47 AM
Home Made Heater
I am looking for novel approaches to putting heat into my 190A Victoria. Pictures of your system will be highly appreciated. In need to get something into my car by November so Christmas parading and icecycle runs will not be frigid experiences.
JohnLaVoy 09-01-2015 08:53 AM
Re: Home Made Heater
When we built the roadster pickup we had heated seats made by LeBarron Bonney and installed those. They work well.
C26Pinelake 09-01-2015 09:15 AM
Snyders sell a great, complete heater with all necessary hardware. Wayne
Rainmaker Ron 09-03-2015 01:05 PM
I built a heater for a Friends slant window using a finned tube oil cooler and two 12 volt computer power supply fans. Two fans equal two speeds. make your own tin box and mount under the seat. Also look at the space in front of the gas tank and behind the firewall. I am thinking of finned tube, baseboard unit here. I haven't done this but it looks doable.
Rainmaker Ron
BILL WILLIAMSON 09-03-2015 02:08 PM
Someone here?? once mentioned that he took out his upper floorboard, to let in engine heat in the COLD WINTER.
Bill W.
C26Pinelake 09-03-2015 03:13 PM
why reinvent the wheel when there is already a commercially manufactured unit of high quality at a reasonable price ? Wayne
Jacksonlll 09-04-2015 08:17 AM
Just use the old manifold heater. It will run you out it gets so hot. I drive my 4 door year round in Michigan. Does a good job.
bettlesr 09-04-2015 05:34 PM
Here is a link to the heater my son helped make for my Sport Coupe
https://www.fordbarn.com/forum/showthread.php?t=161354
post#3
burner31 09-04-2015 11:35 PM
3 Attachment(s)
May not be a "novel" or "new" approach to putting heat in your 190A Victoria.
But might I suggest...
Mitch//pa 09-04-2015 11:48 PM
1st pic no thanks:eek:
2nd pic depends:D
3rd pic sure:)
burner31 09-05-2015 12:15 AM
2nd pic depends:D
3rd pic sure:)
1st pic...tequila
2nd pic...beer
3rd pic...the opportunity
BILL WILLIAMSON 09-05-2015 01:52 PM
2nd pic depends:D
"DEPENDS"--?????????????????????
Dad
burner31 09-05-2015 07:14 PM
7 Attachment(s)
Here's some old time car heaters
I think even you can agree with that...Eh Bill?
hubba...hubba
700rpm 09-05-2015 08:06 PM
hubba...hubba
#6! I love my wife, but Oh you kid!
Pete 09-05-2015 08:37 PM
Weeellllllll, you said novel and I really did this.
I had several A's over the course of going to school and one 2 door I had during a fall and winter I put a small air tight wood stove in the back in place of the seat. Took all of the upholstery out and made a piece of 1/4 inch thick asbestos board to replace one of the back side windows with a 4 inch hole in it that I ran the pipe out and up.
It worked especially well at drive-in theaters.
I burned presto-logs.
katy 09-06-2015 11:58 AM
1 Attachment(s)
Attachment 237646
Mike V. Florida 09-06-2015 11:51 PM
The warming store ;)
Tom Wesenberg 09-07-2015 02:28 AM
Originally Posted by Mike V. Florida (Post 1152171)
Then he'd have to buy a wood cook stove to warm the stone.:D
Gold Digger 09-07-2015 10:15 AM
When I was growing up my uncle had a 1930 sedan with an old kerosene heater tied in the back with baling wire from one window crank to the other. Worked good but we always smelled like kerosene when we went some where.
taffrail 09-07-2015 11:36 AM
I had a hole in my firewall when I got my truck, I thought it would easer to install a heater than patch the hole properly. Look at pictures on line to get the right one, lined it up with the stock treaded hole for the speedo cable clip, happened to match up with an Otwell. It works very well on cold new England days and my wife gets to control the flap.
