The Ford Barn
-   -   Air powered grease gun (https://www.fordbarn.com/forum/showthread.php?t=177118)
ed thibodeau 08-31-2015 05:23 PM
I recently got a air powered grease gun and I need to know what pressure it should be operated at. It probably is a harbor freight unit.
flatheadman 08-31-2015 05:58 PM
Re: Air powered grease gun
I think they are rated for 90-120 psi.
CarlG 08-31-2015 06:00 PM
I have my compressor set at 95#, my Lincoln grease gun works fine with that.
Mitch//pa 08-31-2015 06:05 PM
mine works fine at 120 psi
Will N 09-01-2015 07:24 AM
I ran mine at about 90#, and it blew one of the pressed-in alemite fittings right out of its hole! No problem- tapped it back in, and turned the pressure down to 40#.
