The Ford Barn
-   -   Compression test vs Leak down test (https://www.fordbarn.com/forum/showthread.php?t=177116)
wmws 08-31-2015 04:24 PM
I ran a compression test on my stock A and the range was from 62 to 65 pounds. Then I ran a leak down test and all the cylinders were different with one only registering 18 pounds with 40 applied. Can anyone explain why one test was OK while the other was poor. Thanks for any help.
Big hammer 08-31-2015 04:56 PM
Re: Compression test vs Leak down test
Was the engine held at TDC on compression stroke for each cylinder ?
Where was it leaking from, intake,exhuast,crankcase
bbrocksr 08-31-2015 05:55 PM
Try that leakdown test again. Put the cylinder you're testing on TDC compression stoke and put it in high gear and hold the brakes to keep it from turning. then apply 80 lbs of air to that cylinder and see what you have. Listen at the exhaust, intake, oil filler and take the cap off the radiator and look for bubbles.
A compression test will tell you if you have a problem, A leakdown test will tell where the problem is.
Bill
SeaSlugs 08-31-2015 06:00 PM
Bill
agreed 100%
wmws 08-31-2015 06:29 PM
I did have the cylinders on TDC but I only used 40 LBS. I could hear the leak coming from the intake. One cylinder held 30 LBS and the worst was only 18 LBS. I guess my intake valves are leaking some but the compression test seemed good.
Patrick L. 08-31-2015 06:39 PM
The compression readings are fine. I wouldn't worry about that engine.
40# on the leak test is fine. If you heard the leak on all cylinders from the intake I still don't think I'd worry about it. It does seem as though the engine rolled a bit when the air was applied. Just to be on the safe side I think I'd check the lash.
wmws 08-31-2015 08:26 PM
I'll check the lash. Thanks for the help.
