distributor drive shaft/tang slot Anyone know how far off center (of 1/2" shaft)that the slot AND tang is cut.
Trying to figure out mechanics of refitting a magneto TANG to shaft slot. |
Re: distributor drive shaft/tang slot 3 Attachment(s)
I measured this old shaft...it's as accurate as I can get it..the caliper is all I have for this sort of stuff.....
Re: distributor drive shaft/tang slot Quote:
I will use these numbers to do further research. I'm wondering is Ford had a 'drawing' of what an original shaft measured...as to outside diam and slot tang. |
