The Ford Barn
-   -   Rear radius rod install (https://www.fordbarn.com/forum/showthread.php?t=176150)
Fillinjc 08-19-2015 02:30 PM
1 Attachment(s)
Hi,
I am installing the rear radius rods on my 1930 coupe. I have a new bolt from Snyder's that looks identical in dimensions to the old chewed one. It seems too long as the cross drilled hole for the cotter pin is beyond the castle nut. I assume this is due to wear in the rod ends. Should I just add a washer?
Thanks,
Jerry
Bill Cilker 08-19-2015 03:03 PM
Re: Rear radius rod install
I would add one or two flat washers. If you need to use 2 flat washers, I would put one on each side.
Bob C 08-19-2015 03:09 PM
The bolt 350700-S should be 3 1/8" long.
Bob
Tom Endy 08-19-2015 03:27 PM
This is a problem that has been around for the 25 years I have been involved with Model A's. I have seen it often and do not know the reason for it. However there is a fix, and it should be addressed because it is possible that the nut will bottom out on the threads of the bolt and it will appear tight, but the backing plate is not tight to the axle housing. This will result in the backing plate rocking back and forth with braking and acceleration and it will oblong the mounting holes in the backing plate and ruin it.
For a description of the fix with photos, go to the web site of the Santa Anita A's of Arcadia, California at www.santaanitaas.org. On the home page put your cursor on "Technical Reference", my name will appear below, click on it. A menu of technical articles will appear. Scroll to the heading "Steering", and then to rear backing plates. It is a PDF file you can download and print out.
Tom Endy
Mitch//pa 08-19-2015 03:30 PM
Tom Endy
i thought the OP was discussing the front of the radius rods as shown in his pic
Fillinjc 08-19-2015 03:35 PM
Correct. Front of the radius rods. One washer under the nut will do it.
Thanks,
Jerry
CarlG 08-19-2015 03:43 PM
Tom Endy
I was a little confused when looking at the headings and articles under them. The heading: "Steering", with an article pertaining to "rear backing plates".
Terrific articles though, nevermind how they are indexed! Thanks Tom!
Tom Endy 08-19-2015 04:53 PM
You are all correct, the post was about the front of the radius rod. I did not open the photo and look at it. I thought the subject was about the rear backing plate bolts. My error, I apologize, please disregard everything I posted. However, I am not responsible for the indexing on the web site.
Tom Endy
