Not Model A white Vinyl Interior Could any one tell me what to use to make my white vinyl interior white again. It has darken some. It is about 12 years old.
Re: Not Model A white Vinyl Interior ;)Try Tuff Stuff, made by turtle wax. Great on vinyl,carpet and fabric. I have used it for years.
Re: Not Model A white Vinyl Interior youll get 898 replies of different products take your pick
i use jobbo |
Re: Not Model A white Vinyl Interior Mothers makes a vinyl cleaner. Not cheap but works great! Wayne
Re: Not Model A white Vinyl Interior In an inconspicuous spot, try a bleach type kitchen cleanser.
Bill W. |
Re: Not Model A white Vinyl Interior |
Re: Not Model A white Vinyl Interior Try mr cleans magic eraser.
Re: Not Model A white Vinyl Interior Quote:
When working in dealers shops, I've seen this done by traveling used car re-con guys, LOOKED PRIMO! Don't know about longevity?? Some of those guys are MASTERS at sprucing up cars, like the Ding Doctors, ones that restore HUGE plastic bumpers, rock chips, etc. They're MASTERS at MASKING & make Vinyl dashes/consoles, like NEW! One guy even jacked up a wheel, spun it & with a lathe type bit, turned a shallow area & laminated a thin WHITEWALL into it!! Whether it is your Model A or your Modern Iron, keep these types of CRAFTSMEN in mind. IF you can't locate one, talk to one of your LOCAL Used Car Dealers. When Vermin's finished, I'll have a MOBILE Detailer come my house & give him a WHIZ BANG job & my truck, also! Bill W. |
Re: Not Model A white Vinyl Interior Whitewall cleaner
Re: Not Model A white Vinyl Interior Thanks for all the suggestions. One of them should work. Will let every one know what happens.
Re: Not Model A white Vinyl Interior If all else fails and its vinyl you can paint it white again with vinyl upholstery paint.
Re: Not Model A white Vinyl Interior Well I cleaned it. I wanted to try Bob,s Idea of Tuff Stuff. But could not find any around here. Will try that at a later date. Needed it clean for a grill 57 show.
I used the magic eraser, that helped but not what I wanted. So I used shampoo with a scrub brush, then the magic eraser. That worked real good, but not sure what it did to upholstery, if anything. Thanks for the help. |
