Tudor progress & another spraying tip 2 Attachment(s)
I finished shooting the rock moss green on my tudor. (picture 1) When sanding it down the rock moss (dark) green was definitely under the vagabond (light) green, so that is how I am doing it. Only the upper back, moldings, and wheel wells have fun coverage, the rest has just one quick coat which will be covered by vagabond after masking off the rock moss areas. That comes next.
Here is another spraying tip: Take a sharpie and mark the correct fill lines on your mixing cup (picture 2) so you won't be searching for the correct fill lines (There are hundreds printed on the cup!) while you are adding product. |
