Duel water pumps on the 37 Hello Everyone...I have a 1937 Ford V8 Engine. How does one tell if both the water pumps are functioning as they should? How would I trouble shoot this?
Thanks, Dave |
Re: Duel water pumps on the 37 Each side of the engine is a totally separate system. It is normal for there to be a temperature difference between the sides, but a large temperature difference would indicate a problem.
Re: Duel water pumps on the 37 Take off the radiator cap and look inside. You will see water being pumped through each of the top hoses. If not. One or both of your water pump is shot.
Re: Duel water pumps on the 37 Quote:
washers. Any restriction causes a higher running temperature. You need a hand held laser pointed thermometer to find over heating problems. If one pump is not circulating water or has some type of blockage that side of the engine will run much hotter. It is normal for a few degrees difference. With the laser pointer hold the gun about a foot from the spot you take temperature readings. On a engine with the hoses coming off the center of the heads put the red dot on the metal just below the end of the hose. See what you have then come back and we can zero in on the problem. G.M. |
