The Ford Barn
-   -   what is thread size of hole in distributor for ignition cable? (https://www.fordbarn.com/forum/showthread.php?t=174100)
ericr 07-23-2015 04:51 PM
is it a pipe thread?
Del in NE Ohio 07-23-2015 05:43 PM
Re: what is thread size of hole in distributor for ignition cable?
It is pipe thread! 5/8"?
Tom Endy 07-23-2015 05:54 PM
Whenever I paint a distributor housing I screw in a 5\8" pipe plug (easily obtained from Home Depot). This will keep the paint out and ensure a good ground when the ignition cable is crewed in. I also press in a length of insulated wire into the slot the upper plate rides in. This will keep the paint out and also ensure a good ground. The last trick is to mask off the bottom portion of the housing that sits down in and on the head (also for good grounding).
Tom Endy
Vic in E-TN 07-23-2015 07:10 PM
I am familiar with 1/4, 3/8, 1/2 & 3/4 in pipe sizes. What is a 5/8 in pipe plug?
Vic
BILL WILLIAMSON 07-23-2015 07:27 PM
It "looks" more like 1/4" NPT. Pipe sizes are gauged by the pipes' INSIDE DIAMETER.
Bill W.
Bob C 07-23-2015 08:12 PM
I've never heard of 5/8" pipe either so I went and measured a pop out
cable and it is 11/16-16 NS thread.
Bob
Tom Endy 07-23-2015 08:29 PM
1 Attachment(s)
I think the plug size I have been using are actually 3\8 pipe, not a 5\8. They screw into the distributer base easy with enough threads to keep the paint out. They are pretty thick with paint by now.
Tom Endy
Chris H 07-24-2015 07:22 AM
Be careful if using a pipe plug. 3/8 NPT is 18 TPI. If the thread in the distributor is 16 TPI it could damage the threads in the distributor housing. Just my 2 cents worth.
Chris.
