The Ford Barn
-   -   Floppy axle?? (https://www.fordbarn.com/forum/showthread.php?t=173903)
vern hodgson 07-20-2015 10:54 PM
Floppy axle??
So I pulled my rear hubs to work on the brakes. I discovered something which causes me to ask, is it normal to be able to move the axle up and down, perhaps a sixteenth of an inch or so? Doesn't move in and out but just a little bit up and down and left to right. Do I have a serious problem?
31 Vicky 07-20-2015 11:03 PM
Re: Floppy axle??
Yes that is normal. The axle is resting on the seal, I slip a piece of cardboard between the axle and the housing to take some stress off the seal, keep from reforming it.
A's Always
Dave
vern hodgson 07-20-2015 11:17 PM
Re: Floppy axle??
Thanks, I can sleep easy.
