The Ford Barn
-   -   32 king pin stackup (https://www.fordbarn.com/forum/showthread.php?t=173072)
hb32 07-10-2015 04:47 PM
32 king pin stackup
Not having much luck but looking for the correct position for the bearing, grease cup etc on a 32.
Thanks
Andy 07-10-2015 05:38 PM
Re: 32 king pin stackup
Make sure the top of the spindle is not worn. A lot are. Pin goes into the top of the spindle with the bearing on top of the spindle, then thru the axle and out the bottom of the spindle.
If the top of the spindle is worn the bottom of the axle may drag on the on the lower spindle lug.
scooder 07-10-2015 05:59 PM
Stock 32 parts order as follows,
Bearing slides onto king pin then king pin goes through top spindle eye then axle eye then grease cup and seal then bottom spindle eye.
Martin.
hb32 07-10-2015 06:42 PM
Martin.
Thanks Martin and appreciate the education.
