The Ford Barn
-   -   EV8 vs 8BA starters (https://www.fordbarn.com/forum/showthread.php?t=172342)
russcc 06-30-2015 11:48 AM
EV8 vs 8BA starters
Is there a difference between the 8BA starter and the EV8 on a 59AB ?
What are those differences ? Thank you Fordbarners.
Bruce Lancaster 06-30-2015 12:00 PM
Re: EV8 vs 8BA starters
They changed the aluminum part where it bolts to engine. Early is a sort of cup, late more of a flat plate. Parts book shows same fields and armature, so presumably no change in function.
They interchange freely on 221-239-255 engines except for the automatic transmission ones, and V8 60 is different as well.
The differences between engagement depth of flywheel ring gear between early and late are handled at the starter mounting and so not a barrier to starter interchange.
russcc 06-30-2015 02:24 PM
Thank you Bruce. So if I understand this correctly, to use an early starter in a later engine you have to compensate for the engagement depth by changing end plates ?
Bruce Lancaster 06-30-2015 02:54 PM
No, no...starters have same working dimensions, they slightly moved the mounting surface on engine so they have right reach on each engine. Interchangeable.
V8COOPMAN 06-30-2015 03:04 PM
Don't forget.......early ('32-'48) and late ('49-'53) flywheels should NOT be interchanged. DD
