The Ford Barn
-   -   Radius rod ball (https://www.fordbarn.com/forum/showthread.php?t=172094)
art ebeling 06-27-2015 02:07 PM
Radius rod ball
1 Attachment(s)
I just installed the transmission in my 31 and used the original style radius rod ball socket set I tightened the nuts to the spacers but it leaves a small gap between the upper and lower caps. Is that correct or should the caps come completely together?
Mitch//pa 06-27-2015 02:17 PM
Re: Radius rod ball
your good the bottom cap will float agains the springs
the small gap you see is normal
art ebeling 06-27-2015 02:41 PM
Re: Radius rod ball
Thanks, The Forum is the best place to get answers.
