The Ford Barn
-   -   Fitting for Zenith Carb fuel line (https://www.fordbarn.com/forum/showthread.php?t=171556)
mleder 06-20-2015 09:20 AM
I would like to hook up a temporary test fuel line to a Zenith carb. I would like to stop at a hardware or auto parts store on my way home from work and pick up the male fitting. Would anyone know what the fitting size and type is?.
Tom Wesenberg 06-20-2015 12:11 PM
Re: Fitting for Zenith Carb fuel line
Bratton's calls it 1/2 - 20 threaded fitting, but I'm not sure of the size ferrule the line uses. I would remove an original line from the sediment bowl and turn it up, then slip a clear plastic fuel line over it.
Menards clear tubing has worked well for fuel for me.
Mitch//pa 06-20-2015 12:19 PM
i use a cut off original style line and 1/4 fuel hose
tiger.1000 06-21-2015 08:18 AM
1/2" unf
