The Ford Barn
-   -   PCV valve smokey? (https://www.fordbarn.com/forum/showthread.php?t=171474)
Fatboy Tim 06-19-2015 07:06 AM
PCV valve smokey?
Wee question from Scotland.
I have rebuilt the flathead in my 32 coupe, now 284 inch, compression is 135 each cylinder so not bad. PCV valve fitted and getting a bit smoke out the exhaust under hard accelaration / 5000rpm. I think this means the PCV valve is working with a dump out the inlet manifold. No smoking at idle so new valve seals seem ok.
Any advice welcome.
Thanks for looking.
Dave
40cpe 06-19-2015 09:10 AM
Re: PCV valve smokey?
I don't see how the PVC valve could cause the high RPM smoking. It is more likely your rings haven't seated yet.
Fatboy Tim 06-19-2015 09:24 AM
Thanks, good point.
Dennis Jarrell 06-19-2015 02:15 PM
how did you get a pvc to work at all?
Ross F-1 06-19-2015 02:27 PM
How often do you spin it up to 5,000??
scooder 06-19-2015 03:24 PM
He lives in the British isles, with a built flathead, so I'd say a lot.
Tis how most of us drive them, like we stole it.
If I put a bunch of work building a "hot" flathead, id spend a good portion of my time trying to break it, after all that's what I built it for.
Martin.
scooder 06-19-2015 03:28 PM
Forgot to add,
Tim, how many miles on this engine?
Martin.
B-O-B 06-19-2015 05:07 PM
Curious as to what color of smoke? White blue or black.?
Brendan 06-19-2015 05:32 PM
i bet that coupe runs like a raped Ape!...LOL
Fatboy Tim 06-20-2015 02:41 AM
Smoke is grey, engine is a French block so not a lot of miles on it. PCV valve is connected direct to the underside of the inlet manifold.
Thanks for the advice.
scooder 06-20-2015 04:09 AM
Grey? Oil is Blue mate.
Keep an eye on it.
Martin.
Bluebell 06-20-2015 06:14 AM
And too much petrol is black.
Gray smoke? Is it using water?
Fatboy Tim 06-20-2015 07:55 AM
Will give it a wee blast tomorrow and check, thanks for the advice.
Fatboy Tim 06-20-2015 08:30 PM
Found the answer, drive the t#ts of it , if / when engine grenades stick in a 327.
I think that's what happened in1955 too.
40cpe 06-20-2015 09:07 PM
No 327s in 1955, not chevy anyway. :)
scooder 06-21-2015 05:50 AM
And bloody definitely shouldn't be in a Ford!
Martin.
35cab 06-21-2015 03:26 PM
Living next door to this man, I can vouch for the fact he does drive it hard and he likes using all the numbers on the tach! It was me that noticed the odd puff of smoke as I struggled to keep up with him on our drive back from the Lake District.
It is a great driving car and don't worry Martin, he will not be allowed to put in a ch*vy, or any of these new fangled ohv engines in it, I will weld his toolbox shut.
The smoke is a bit of a mystery, perfect compression on all cylinders, no oil water contamination, no odd noises, to be continued. . . .
Fatboy Tim 06-22-2015 07:00 AM
Thanks Gordon, don't ask me to weld up my toolbox as the welds will break...........cant get the penetration these days.
