'40 front brake hose to short Does anyone have a part number for a front brake hose 19" long?
Re: '40 front brake hose to short Does it matter what the ends are? male/female Chevy, Ford.
Re: '40 front brake hose to short Quote:
Re: '40 front brake hose to short The # is for stock FC7600 15 9/32 long Front
You could try FC4774 18 13/32 Same thread. The mounting hole must have been changed. |
Re: '40 front brake hose to short |
Re: '40 front brake hose to short Sorry, I should have been more clear. I am putting '40 brakes on my '32. The hole in the frame is drilled just behind the stock shock, this makes a stretch for a 16 7/8" hose. No room for suspension flex, that's why I am thinking 19" will work good.
Karl |
Re: '40 front brake hose to short Wagner Raybestos 4497 is longer than the 40 front hose.
John |
Re: '40 front brake hose to short I had a similar hose length problem. I found that searching NAPAs online cat will give you a hose that will work. It may take some time searching thru the many options but you find one that will work. Here is an example
http://www.napaonline.com/Catalog/Ca...242_0342278658 I'll look for the part# I used in the morning. |
Re: '40 front brake hose to short The Wagner FC 4774 is 18 13 /32 try Plymouth 35-38
FC 4950 Divco and IHC 20" long. |
Re: '40 front brake hose to short Another option is to have them made--the local hydraulic hose place here can make brake hoses ---any length up to what's on the roll in one piece
Re: '40 front brake hose to short Go to your local Napa store. Have the counterman get out the brake hose buyers guide. In this catalog you will find descriptions of all the hoses that Napa lists, by length, type of fittings and any mounting brackets.
Re: '40 front brake hose to short Thanks for the help. Going to NAPA to go through their book.
