The Ford Barn
-   -   32 model B dash light switch power source (https://www.fordbarn.com/forum/showthread.php?t=170364)
B-nut 06-04-2015 08:08 AM
Where does the power come from to feed the dash light and switch? The wiring diagram is not very helpful in this area. Thanks.
JSeery 06-04-2015 08:31 AM
Re: 32 model B dash light switch power source
1 Attachment(s)
The diagrams I found is fairly easy to read, if it is correct for the entire model year! There is a Yellow wire from the starter battery terminal to the amp meter and then a Black wire from the same terminal of the amp meter to the dash light switch. The dash light switch is connected to the dash lights. The other terminal of the amp meter is connected to the generator with a Yellow/Black wire and to the lighting control switch (at the base of the column) with a wire that is also Yellow/Black.
