The Ford Barn
-   -   Model A overdrive speedometer cable (https://www.fordbarn.com/forum/showthread.php?t=169494)
4t8merc 05-24-2015 04:41 PM
I am looking for a speedometer cable that fits my 1930 Ford Model A with a Borg Warner overdrive. The cable is attached to the overdrive unit with a bolt and clamp. The outer casing has a round end that fits into the overdrive unit with the bolt and clamp holding it in place. The upper end of the casing has a fitting with male threads that fits into the original Model A speedometer cable. This cable is approx. 38" long. Also, looking for the plastic gear that the cable fits into in the overdrive unit. Thanx for looking.
MAG 05-24-2015 06:39 PM
Re: Model A overdrive speedometer cable
http://hermtheoverdriveguy.com/?page_id=889
Have you tried this site?
