1932 ford vacuum wiper motor Does any anyone have a 1932 ford sedan working vacuum wiper motor are anyone that rebuilds them Thanks Bruce
Re: 1932 ford vacuum wiper motor Before you go too far try dripping a little ATF down the tube where the vacuum line attaches while you are moving the blade back and forth. Sometimes you get lucky. If you don't get lucky try a search, the name "Fricken" seems to come up a lot.
Charlie Stephens |
Re: 1932 ford vacuum wiper motor Rebuilding one is pretty straightforward. You can obtain parts like the required gaskets and even a new paddle (the only moving part) from A&L Parts Specialties in Canton, Connecticut.
Re: 1932 ford vacuum wiper motor 1 Attachment(s)
Kent Jaquith in Oregon rebuilds them.
