Front Brakes Draging
Re: Front Brakes Draging What year and model are you working on?
Re: Front Brakes Draging 1940 ford
Re: Front Brakes Draging Loosen the 2 top cams on the backing plate until they stop turning and then back off a bit, if the drum still won't come off over the shoes loosen the bottom 2 adjusting 3/4 nuts and turn the inner ones so the dot on the ends point to each other. Walt
Re: Front Brakes Draging Sounds like the wheel cyl isn't retracting. How about taking the lower adjusting studs nuts off and try to wiggle the drum off. If it doesn't work then go take the wheel cyl screws out and try it. Lastly, take the backing plates and all off together.
Re: Front Brakes Draging Hi Fellows,took your advice and it worked. Thanks John
