The Ford Barn
-   -   Spark plugs (https://www.fordbarn.com/forum/showthread.php?t=167106)
Redbird 04-23-2015 06:28 PM
Spark plugs
3 Attachment(s)
I am not sure when the spark plugs were last changed. They were Champion C-16C. I bought a set of Motocraft SP-488 TT10 from Bert's. The ones I took out are pictured for your review. Are the tips supposed to be to the side of the electrode? I am still waiting on my radiator before I fire it up. Bert's offers three different plugs. What does every one use?
mshmodela 04-23-2015 06:59 PM
Re: Spark plugs
There is thread here that shows the temperature range for several plugs. I had TT10's but were too cold from my standard compression head as well as my short trip city driving... I've tried these:
W16Y
W18
https://www.fordbarn.com/forum/showthread.php?t=6458
glenn in camino 04-23-2015 07:42 PM
Re: Spark plugs
Except for my one modified A ,I use my restored 3X plugs.
jax55 04-23-2015 07:53 PM
Re: Spark plugs
Looks to me like the old plugs are plain worn out. If you are doing a lot of around town driving, get a hotter plug (If you have an original head) and use a colder one if you are touring a lot or have a high compression head.
Mitch//pa 04-23-2015 08:00 PM
Re: Spark plugs
i run the 3x's
BILL WILLIAMSON 04-23-2015 08:04 PM
Re: Spark plugs
C-16-C
Bill W.
Mitch//pa 04-23-2015 08:08 PM
Re: Spark plugs
Originally Posted by BILL WILLIAMSON (Post 1074338)
C-16-C
Bill W.
i might just send u 4 spanking new 3x's..
will u use them?
BILL WILLIAMSON 04-23-2015 08:53 PM
Re: Spark plugs
will u use them?
DUZ A DUCK HAVE WEBBED FEET?:D:D:D:D
Quacky Dad
Tom Wesenberg 04-24-2015 05:45 AM
Re: Spark plugs
Some ground electrodes are made on the side of the center electrode, and some plugs (most plugs) are made with the ground electrode over the end. The color looks fine on the removed plugs, and if the gap is within specs, they should be good to use.
Patrick L. 04-24-2015 06:27 AM
Re: Spark plugs
Those sparklers seem to look fine. As long there are no cracks and the center electrode and insulator looks good then you can adjust the gap and run them. Side gap plugs are common.
Redbird 04-24-2015 06:33 AM
Re: Spark plugs
Thank you. I have never seen side gaps before.
BILL WILLIAMSON 04-24-2015 10:01 AM
Re: Spark plugs
Redbird,
I once ran an OLD Datsun 510, with the ground electrodes cut OFF, it ran good.
Bill W.
JD 1931 04-24-2015 01:46 PM
Re: Spark plugs
I run champion w-18, lots of stop and go here...
1931 flamingo 04-24-2015 02:50 PM
Re: Spark plugs
W-18's here.
Paul in CT
