Very nice brake job Nice but expensive brake job from Snyders, new cast iron drums trued to hubs, shoes arched to drum and all new parts inside, woven shoes as original. Somehow Fedex delivered 3 out of 4 drums from Snyders. I guess the other one will come tomorrow.
http://i371.photobucket.com/albums/o...psacch1mmp.jpg http://i371.photobucket.com/albums/o...psfjuqvwkf.jpg http://i371.photobucket.com/albums/o...psgqtjnm0w.jpg Someone else will be enjoying the fruits of my labor. If I can ever get them done I'll be selling a 29 roadster with fresh restoration and 28 early open cab pickup fresh restoration, both with new brakes. The 28 has many early features, more like name the parts that aren't early. Next on the agenda is shimming the body so the hood will fit on the 29. I tried an 1/8 inch shim on the front and it lines right up. Then respray the hood. This was my first paint job and didn't get enough paint on the hood so it doesn't match the body color. Wish I had known to spray 4 coats of color... Then off to get new LeBarron Bonney interior and top. I already had a new top and interior but I bought it 7 years ago when I thought it would be cool to have a 30/31 style interior and top on my 29. Back to stock. The 28 needs the passenger side door painted. Two cars at a time to finish makes for long days. Nice to be retired but have been working on 5 cars since Jan 2010. 3 almost finished plus two Model As |
Re: Very nice brake job After all that work and expense it is a shame you won't enjoy it. For whatever reasons I wish you good luck. Wayne
Re: Very nice brake job Quote:
Re: Very nice brake job Looks like you are doing a first class job. The car will be very nice when you finish it.
Brakes are expensive to do correctly but when the car is finished, it will be a real pleasure to drive knowing the brakes will work as they are supposed to do. Keep up the good work. Chris W. |
Re: Very nice brake job just working on them is enjoyment. a labor of love
very nice job TEX |
Re: Very nice brake job Looks like someone will get a very nice 29 when it is done. Great job so far.
Re: Very nice brake job I think that just about everyone on FB, if a genie would give them three wishes, at least one would be for a bigger garage.
Re: Very nice brake job Those backing plates, shoes and drums look beautiful. But don't forget the rest of the braking system! If the brake pedal is loose on its shaft, and the brake cross shaft bushings are sloppy, and if the clevis pins are loose in their holes, only a fraction of the pedal motion is going to make it to those lovely new brake shoes.
Good luck ! Wayne |
Aint it the truth! |
Re: Very nice brake job Your drums and shoes look great, but I have concerns about using woven linings with cast iron drums. From my own experience, I have found that the bonded linings will work much better with cast iron drums - seems the woven linings work best only with the original steel drums. Again just my opinion. It appears that your project is well on the way and shows a lot of time and effort. Good luck with your project and best wishes toward a speedy completion.
Dick |
Re: Very nice brake job Very nice! Love the color combo. What are the colors/codes?
