'28 Roadster Door Latch question Will a Roadster door latch from a '28 fit and work in a '30 Roadster door? I've got a no outside handle situation and this would be an easy fix if it worked.
Thank you, Tim |
Re: '28 Roadster Door Latch question Not the same.
Are you trying to install outside door handles on a 28? If so, why? |
Re: '28 Roadster Door Latch question No, I have '30 doors with no handles holes and I am looking to see ifI can use '28 door latches without the outside handle spots.
