1939 ford flathead gas problem I own a 1939 ford, my problem is it won't start .. I live in the northeast and let the car sit without adding any stabilizer to the gas .. When I first tried starting it it only ran for 20 minutes then it stalled, I am getting gas to the I'm carburetor Could any tell me if the gas would cause the car to not start. Other than emptying the old gas from the the tank and blowing out the gas lines to the carburetor would I have to get the carburetor rebuilt in order for it to run .. Would it be advisable to try to start it with just emptying the old tank and add a new gas? Has anyone has this and if so any advice would be appreciated!!
Thanks, Jim S |
Re: 1939 ford flathead gas problem Quote:
Re: 1939 ford flathead gas problem As G.M. suggests, check spark first. Condensers go bad sitting. If you have spark, the gas could be bad. Depending how long it sat, the new gas goes bad quick. If it does not smell fresh, it is probably lost of lot of it's oomph. Just started a tractor that sat over the winter. Gas turned yellow, started, quit. No start. Drained the gas carb bowl, flowed new gas through it, and it ran fine after that. Maybe just bad gas.
