The Ford Barn
-   -   Water Pump Won't Take Grease (https://www.fordbarn.com/forum/showthread.php?t=166201)
Pilotdave 04-12-2015 08:11 AM
I just installed a new leakless water pump on the Tudor. It came with instructions for greasing the rear bushing.
The instructions are to loosen the packing nut and pump grease into the brass fitting until it comes out around the shaft. One is supposed to do this every 500 miles.
I can't get the fitting to accept any grease - what little goes in dribbles back out through the nipple on the fitting. I removed the fitting and see that there's grease in the cavity behind the fitting.
Does this sound like a defect in the pump? How might I repair it?
Thanks much.
Dave
JtownJoe 04-12-2015 09:25 AM
Re: Water Pump Won't Take Grease
I am also having the same issue with the front fitting. I did try a new grease fitting just in case, with no success, I dread the thought of tearing the pump back off! Ugh.
BILL WILLIAMSON 04-12-2015 10:07 AM
"Maybe" they are SEALED bearings that require NO GREASE??? "Maybe" call your supplier for more info??
There's a lots of variations in "leakless" water pump bearing set ups ! !
Bill W.
Pilotdave 04-12-2015 10:47 AM
Bill, the front bearing is sealed - no greasing required. The rear bushing is not sealed and the pump comes with instructions that clearly state it needs to be greased every 500 miles. I will be calling my vendor Monday but am hoping there's a fix.
Dave
Bob C 04-12-2015 10:58 AM
Have you tried taking the fitting out and sticking a wire in there
to make sure the passage is clear?
Bob
Tom Wesenberg 04-12-2015 11:08 AM
This is a good lesson for us to try the part before installation. We need to grease the fitting before installing the pump. It does sound like you have a defective part, and will need to remove it since it won't take grease.
Pilotdave 04-12-2015 11:21 AM
Bob C, I probed the cavity behind the fitting with an awl, but the cavity is full of grease so it's very difficult to know whether there's an opening at the back of the cavity and/or if the grease can flow around/into the bushing.
Tom, you are so right. I've wrestled with repro part issues throughout my project. The pump is going back to the vendor tomorrow and I think I'll bring my grease gun so I can check it before leaving his shop!
31Abone 04-12-2015 11:24 AM
I have same problem with Snyder's leakless ..back grease fitting does not want to take grease..???
Brian T 04-12-2015 01:35 PM
My leakless is the same way, it has been on my engine for some time, here is the answer.
http://www.snydersantiqueauto.com/4910
Pilotdave 04-12-2015 03:29 PM
Hi Brian. My pump is the A-8502 (I still have the box it came out of) as opposed to the A-8503. The 8502 is supposed to be greased, the 8503 is not. Both are leakless.
Mitch//pa 04-12-2015 04:57 PM
if your going to go leakless get the one that needs no greasing at all
and get the best pump you can
http://leaklessapumps.com/extreme.htm
heneste 04-12-2015 05:04 PM
I also have one of the leakless water pumps that needs grease at the rear bearing and it takes it without a problem. I don't recall if I had to grease it immediately after installing or if it was already pre-loaded with grease.
If the fitting is just plugged, some hardware stores sell a sliding tool to force grease through the fitting if there's an obstruction.
Pilotdave 04-12-2015 05:29 PM
Mitch, I'm considering upgrading to the totally leakless pump... it's only money. :)
heneste, thanks for the suggestion. I've checked the fitting - it's not plugged; the problem is internal to the pump.
Brian T 04-12-2015 06:04 PM
I think I would call the vendor first, hopefully you get to speak to someone knowledgeable, greasing a water pump seems to be going backwards, anyone not knowing is likely to keep pumping grease waiting for it to appear somewhere, probably blowing out the seals, using the grease fitting for the rear wheel bearings is an example, in all my years in the repair shop I haven't yet seen a leakless water pump.
Mitch//pa 04-12-2015 07:05 PM
dave i had issues with the quality of the suppliers all greaseless pumps. they all started leaking coolant so thats why i mentioned about buying the best
it's only mooolah;)
Rex_A_Lott 04-12-2015 08:19 PM
You worry too much. Drive the car. Have you driven the 500 miles???
Probably not.Drive.... Drive some more.
Good Luck!:)
8aflyboy 04-12-2015 09:34 PM
4000 miles and no grease. just drive it.
Ron W 04-12-2015 10:01 PM
Dave, info for your pump says that if you tighten the collar, you will not be able to get grease in! Check this link. Ron W
http://www.snydersantiqueauto.com/up...nst-11284..pdf
Mike V. Florida 04-12-2015 10:21 PM
Newer is not always better. Tom, how many years/miles without a leak on your stock pump?
Tom Wesenberg 04-13-2015 01:03 AM
I never kept track of the miles, and it would be less than many on here, but I rebuilt it totally stock in the early 90's, then installed it on my 28 about 15 years ago and it never leaked a drop. Last year I removed it and installed the rear bushing with the rear double lip seal, just to better keep the antifreeze and grease seperated.
