46 Interior dome lights help needed. 1 Attachment(s)
good afternoon gang....I have been looking on the web for interior dome light parts and have found a harness that Macs etc has but not with the spring assembly. Is there a wiring harness available with the spring included for the bulb housing?
I have the housing with the switch included but the mechanism is worn out and fallen apart. I will try to fix this but if not a door button seems like a good option. and since i know diddly squat when it comes to electrical hopefully someone can chime in with some info. thanks |
Re: 46 Interior dome lights help needed. I believe that any single wire socket with a spring will work.
Re: 46 Interior dome lights help needed. Midwest Part No. for dome light switch is/was A-13769.
Re: 46 Interior dome lights help needed. 1 Attachment(s)
thanks :) found the switch and it should fit with a bit of modifying. Thanks for the info on the wire, like i said i just go blank when it comes to wiring :confused: i found it... here is some info on that.
JT&T (2840F) 1-WIRE UNIVERSAL SINGLE CONTACT DOME, GLOVE BOX, MAP LIGHT & MULTI-PURPOSE 'SNAP-IN' LIGHT SOCKET, 1 PC. |
