The Ford Barn
-   -   ridge remove lube (https://www.fordbarn.com/forum/showthread.php?t=164769)
pooch 03-26-2015 01:48 AM
ridge remove lube
Shortly I will be starting my new project, and the first job is to de-ridge the bore so I can disassemble the engine.
Is any lube used on the ridge remover or dry ?
colin1928 03-26-2015 03:12 AM
Re: ridge remove lube
Pooch ideally a ridge remover works dry
I how ever pack the cylinder with heavy grease to catch the metal filings and clean before raising each piston
If it has large ridge and will need to be rebored I skip removing the ridge
Mart 03-26-2015 03:20 AM
I believe cast iron is always machined dry.
Mart.
big job 03-26-2015 05:34 AM
Yes dry any lube causes a build up on the cutter which you constantly have
to clean.
Ronnie 03-26-2015 09:47 AM
Dry
There is a set up procedure,follow it as a poor job will be the result.
R
