What do you think of this Babbitt 2 Attachment(s)
This set of caps is ready to be cut to fit the crankshaft, I didn't pour them, but I know where it was done
Re: What do you think of this Babbitt 1 Attachment(s)
Kurt: Looks like was peened with KRW tool ,not good enough.
if you are going to use them on your own car i would suggest peening them yourself. We have a special tip for our air hammer. We reduce air pressure and peen aross entire surface enusre a tight fit. www.jandm-machine.com |
Re: What do you think of this Babbitt ID yet to be machined. Ok with that.
Is it my eye or the distance between the camera and cap or do those "ramps" at exit and entrance go right to the shell? Is this normal? Might these be thin at the flange/parting? A cast in ramp I might consider possible, but aren't the ramps normally machined as part of the grooving? And to leave SOMETHING at the cap and block mating surface? Joe K Edit: The J&M pix from the other thread is more what I might expect from the ramps. Smaller and leaving some metal at the match line. https://www.fordbarn.com/forum/attach...1&d=1427290362 |
Re: What do you think of this Babbitt Quote:
They are N.O.S. Ford Caps! Herm |
Re: What do you think of this Babbitt 14 Attachment(s)
If the caps are poured right, they will not fail. So always run the oil wells to the steel, to get the most capacity for the oil wells. Herm. |
Re: What do you think of this Babbitt 12 Attachment(s)
Model T and A babbitt that has failed. The first one is a Model A that was done buy a company that does several blocks and rods a year.
Re: What do you think of this Babbitt Yes, they are NOS,yes the rear cap was primed with air hammer, this is what you would get at the dealer when Babbitt was poured in the block -- new caps
I found some pictures and description of the process in some web reprints of American machinist, the Babbitt wasn't poured, it was done in an injection moulding machine |
Herm. |
Re: What do you think of this Babbitt Could you explain to a novice at machining why peening has to be done ?
Why is hot pouring not sufficient ? Does the babbit need to be compacted ? |
but now I can answer that. No. 1. 2. & 3. When babbitt is poured in a block warm, or cold, with out tinning, it will shrink away from the shell, nothing to grab on to. If it shrinks away, and it will, it will be loose in the block. So being that the babbitt is not up against the block shell, you have to give it a big push to where it should be, with peening. A good side effect of peening is as you say compacting the babbitt. You have to do this while very hot, or it will fracture the babbitt against the shell wall, and you would not see untill the bearing went bad, in a few short miles, as many do. So also if it isn't peened, the crank will do it for you when cold, and as of the many pictures on the form, you can see what happens. Now many people mistakenly beleave that the anchor holes in the block are to hold the babbitt from falling out, and it only works when you hold the block right side up. lol Not true, the anchor holes ar there to keep the babbitt insert from spinning, as a notch on a modern bearing. If the babbitt isn't peened, those anchor don't hold anything in, they just bust out on the main part of the bearing. Thanks Herm. |
Re: What do you think of this Babbitt Thanks for the explanation Herm, Pooch wasn't the only one wondering.
Re: What do you think of this Babbitt Same here, thank you Herm for posting and the pictures. Learning some good stuff!!!!
Re: What do you think of this Babbitt Thanks Herm, but you said one thing that I CAN answer.
The notch in an insert bearing is NOT to stop it from spinning. It is just used to locate the shell. Bearing crush is used to stop the spinning. |
The real name for the notch, is called a Locking Lip, funny they would use locking in a term like that. So, all bearings have to have crush, that keeps the bearing tight to the walls of the shell. All bearings have to have a way to lock the bearing from spinning. Before the Locking Lip, bearings were locked with shims that hung into the part lines, or they had brass pins the stuck out of the bearing shell and the brass, or steel bearing shell sliped over them and locked them in place. Many had Brass screws, could be one, or two, and that locked the bearing in. Some had Brass rivets in them, 4 to a 1/2 shell. You don't need a Locking Lip, to line two inserts up, any one can do that and get them even, but you always need some way to lock a bearing from spinning, and as you know, when a bearing goes bad, that won't even be enough help. Thanks Mr. Pooch Herm. |
That engine looks very familiar. :) Still running great after several thousand miles. Thanks!!! |
Re: What do you think of this Babbitt ' Now many people mistakenly beleave that the anchor holes in the block are to hold the babbitt from falling out, and it only works when you hold the block right side up. lol
Not true, the anchor holes ar there to keep the babbitt insert from spinning, as a notch on a modern bearing. If the babbitt isn't peened, those anchor don't hold anything in, they just bust out on the main part of the bearing.' If, say the holes in the block were not there, would a peened babbitt job actually be loose and fall out, if block was turned upside down ?. Does it only hold on at the hole spigots? Just interested, I always assumed without any knowledge the babbitt was adhered similar as a solder job would be, all along the backface and edges. |
I am glad you are making use of that nice original truck. It sure looks different then when you pulled it out of the old shed after 60 years. I wish I had it, and you had a better one. Take care, Herm. |
Try taking a large chunk of cast iron and getting it hot enough to tin it. Good luck! that is exactly what it would take to make the babbitt adhere. As the babbitt cools rather quickly (as the alloy requires to maintain it's functional properties), it indeed shrinks away from the block. The babbitt needs to be peened to expand it back tight against the saddle. The poured babbitt does form cleats in the drilled pockets in the saddle but have little strength by themselves if the babbitt is loose in the saddle. As Herm inferred, something in the babbitt will break if the shell is left floating. The lug or cleat formed in the babbit COULD sheer but the area of the shell above it is typically a weaker link and apt to break away from the rest of the shell. |
Re: What do you think of this Babbitt 6 Attachment(s)
Chevy 4 cylinders used solid babbitt inserts, in there front, and rear bearings. They were Jig poured, and had one single lug to keep them from spinning. Same thing as T's, A's, and B's. I will list some pictures, of the replacement bearings for the Chevy Fours. Thanks, Mr Pooch, Herm. |
