'31 2 dr sd garnish moldings I have a 31 2 dr sd that did not come with any garnish moldings for the rear qtr windows. Am I looking for 2 piece units or are they one piece on each side?:confused::confused::confused:
Re: '31 2 dr sd garnish moldings Give Bert's in Denver a call. 800-321-1931
They are closed Sunday and Monday. |
Re: '31 2 dr sd garnish moldings My 31 tudor has 2 piece garnish.
Re: '31 2 dr sd garnish moldings thanks for the input fellas.
Re: '31 2 dr sd garnish moldings can any of you fellow tell me if the upper mouldings can be removed without removing the upholstery on the 31 Tudor. my memory seems to tell me that there are two tabs with screws into the wood framing, but I have not seen one apart for 20 years. I would like to remove mine and try woodgraining them as a winter project if it is not too big a job. thanks ..Jim.
Re: '31 2 dr sd garnish moldings There are two tabs at the front of the window trim with screws into wood. There are two tabs at the back that the frame hooks onto. My tudor was missing all upholstery except the seats. It looks like there needs to be a piece of upholstery covering this small area.
Re: '31 2 dr sd garnish moldings Thank you. Just what I needed to know. It is minus seventeen up here this morning with a forecasted high of minus five, so it looks like I have time to tackle a little project like this before I can get the car out. Thanks, Jim.
