The Ford Barn
-   -   Windshield (https://www.fordbarn.com/forum/showthread.php?t=164323)
latecomer 03-20-2015 05:12 PM
Windshield
Hey guys need a little help on disassembling the inside of my 29 tudor windshield frame.Thanks in advance. latecomer
Big hammer 03-20-2015 05:31 PM
Re: Windshield
Lay it down on a work bench, in the upper corners are 4ea #6? screws in both sides. Remove the screws, lift the top piece off, slide glass out. You will need a good screwdriver,and I like valve grinding compound on the tip. You may need oil,heat to get screws loose. Sorry CRS about the bottom, you see what's needed :-)
Tom Wesenberg 03-20-2015 06:12 PM
Re: Windshield
I think there is also another screw on each top corner, for a total of 3 per top corner. I like to soak them with Kroil then use a screwdriver with a nice flat tip.
Screwdrivers used as gasket scrapers don't qualify.
BILL WILLIAMSON 03-21-2015 07:05 AM
Re: Windshield
HOLLOW grinding the screwdriver tip helps, also.
Bill W.
silversink 03-21-2015 12:19 PM
Re: Windshield
I soaked mine for 3 weeks and couldn't get them to budge--ended up getting an impact driver from HF and one wack each them came right out, the glass was another story-----it came out in pieces.
latecomer 03-22-2015 07:48 AM
Re: Windshield
Hey guys an other question on the 29 windshield,is the top hinge attached to the top section of the frame? thanks latecomer
rocket1 03-22-2015 08:19 AM
Re: Windshield
The screws that are in the right and left top corners in the face of the windshield frame have nuts behind them,also the top hinge will come off the windshield frame if you soak it for about a year,just kidding!
Ted Duke 03-22-2015 09:25 AM
Re: Windshield
Patience is the answer. Soak with your favorite soaker and tap the screws lightly with THE screwdriver that fits. Patience.
Tinbasher 03-22-2015 05:41 PM
Re: Windshield
Check the top hinge and see if the ends are crimped over. Sometimes you have to straighten the end so you can slide the hinge off of the frame. Don't try to pry or roll it off the top. Soak it well and then use a wood block on the hinge parts and tap it off of the frame. Tap don't beat, as you'll damage the hinge.
Mike V. Florida 03-22-2015 11:29 PM
Re: Windshield
1 Attachment(s)
Here is a tool that was made for the tough stuff.
