The Ford Barn
-   -   Deck (trunk) Lid Hinge Bracket... (https://www.fordbarn.com/forum/showthread.php?t=162312)
Steve Plucker 02-24-2015 08:52 PM
On the Deck (trunk) Lid there are two brackets, both on the upper corners, left and right, and inside the lid.
The two brackets are connected to the lid by the means of a flat head rivet (YES DUDLEY...IT IS A RIVET AS YOU WELL KNOW).
The question is, was this a solid fit by the rivet OR was there supposed to be some slight movement of the brackets for means of adjusting the lid squareness?
Thank you.
Pluck
jw hash 02-24-2015 09:29 PM
Re: Deck (trunk) Lid Hinge Bracket...
Pluck
on my NOS deck door the bracket is riveted in the center you can move it up or down for adjustment but it is tight. I put a punch in the hinge screw and tapped with a hammer to get it to move.
d.j. moordigian 02-25-2015 10:37 AM
1 Attachment(s)
Originally Posted by jw hash (Post 1039887)
Pluck
John,...that's how I figured it was, as far as the movement...
The question for me, and I know Pluck is also interested;.....
Do you see a "shim" in there?... it should look like this..
jw hash 02-25-2015 01:22 PM
2 Attachment(s)
there is NO shims in in mine. there was no screw lock washer & nut in it when I got it so I installed them so you can see how it goes.
